Dennis Zetak Chefmechaniker
Anmeldungsdatum: 19.04.2017 Beiträge: 75 Bilder im Album: 0
Verfasst am: Sa Nov 28, 2020 11:16 Titel: NGP (Next Generation Physics) Plugin |
In rbr, doesn’t matter how long is stage, the pressure from for example 200kpa goes to 202kpa. I saw it on telemetry |
Viktor GVRC Veteran
Anmeldungsdatum: 31.12.2010 Beiträge: 3618 Bilder im Album: 172 Bilder in P. Galerie: 98 Viktor's P. Galerie Wohnort: Berlin  |
Verfasst am: Sa Nov 28, 2020 14:03 Titel: NGP (Next Generation Physics) Plugin |
If you want to simulate a more or less correct tyre pressure you'd need to have a way more complicated tyre model which takes a lot more physical properties into account:
- tyre flexing/stiffness which acts on many variables (e.g. generates heat to mention one)
- ambient temperature of air and ground surface (in sunshine those could be quite different, dependent on how surface interacts with sunshine)
- change of tyre contact patch surface by various variables
- heat flow (air & aerodynamics, ground surface, tyre rim, heat contribution from brakes which depends on aerodynamics and more, ...)
- change of tyre properties by temperature
- ... (I surely forgot or don't see some to mention more)
The tyre model can get arbitrarily complicated. In my opinion simulating proper tyre pressure makes only sense if your tyre model takes care of tyre flex/stiffness and temperature dependence of various tyre properties. Getting reliable data for such things is almost impossible and for rallying you'd need to take care of tarmac, gravel and snow/ice which multiplies the difficulty to obtain the data even more.
Sure, would be nice to have, but very difficult to implement properly.
With today's computing power of gaming computers and graphic cards you could simulate way more complicated things easier than in the times when RBR was created. Did the current top circuit track racing games find the "holy grail" of tarmac tyre simulation? OK, I know, forgive me to go a bit to the extreme edge with "holy grail". I guess no, more kind of "good enough" to sell. They may be better in their tarmac niche than NGP-RBR (I claim that without experience of circuit track racing sims as those are not my playground, but I follow slightly what's going on with other racing sims) but again rally sims have more surfaces to cover properly. _________________ „Lieber glaube ich an Wissenschaftler, die sich mal irren, als Irren, die glauben, sie seien Wissenschaftler.” |
Cristian Lamas Mechaniker
Anmeldungsdatum: 06.11.2018 Beiträge: 41 Bilder im Album: 0
Verfasst am: Di Dez 01, 2020 17:17 Titel: NGP (Next Generation Physics) Plugin |
we are in luck, workbee has added the Ford Fiesta Rally4 to RBRCiT !!!
I have a question, my apologies if I'm wrong .... M-Sport declared 200hp in the 2019 Fiesta R2T and 210hp in the Fiesta Rally4.
In RBRCiT the two cars are listed with 200hp, I don't know if it's a text error or if the error is mine.
Here is a text that can be read on the M-Sport website:
"The award-winning 999cc turbocharged Ford EcoBoost engine has been optimized with increases in power and torque delivering 210 bhp and 315 Nm respectively. The 2020 Ford Fiesta Rally4 sees improved gear ratios and stronger driveshafts to better handle the delivery of the increased power and torque."
Fabz Chefmechaniker
Anmeldungsdatum: 24.07.2017 Beiträge: 156 Bilder im Album: 0
Verfasst am: Di Dez 01, 2020 18:54 Titel: NGP (Next Generation Physics) Plugin |
You're right. It should be 210hp. |
jansku22 Mechaniker
Anmeldungsdatum: 10.09.2017 Beiträge: 27 Bilder im Album: 0
Verfasst am: Mi Dez 02, 2020 16:49 Titel: NGP (Next Generation Physics) Plugin |
A number of key aspects of the Fiesta Rally4 have been enhanced from its predecessor with particular attention to its handling characteristics, prompting improvements to the suspension and the use of a lighter exhaust. The increase in power and reductions in weight mean that the 2020 EcoBoost-powered Ford Fiesta Rally4 will have the best power to weight ratio in the RC4 class.
Fiesta R2 2019 200hp and 290nm
Fiesta Rally4 210hp and 315nm
P.D: its most direct rival, the Peugeot 208 Rally4 declares 208hp |
Verfasst am: Fr Dez 25, 2020 14:28 Titel: NGP (Next Generation Physics) Plugin |
A nice christmas present from GR Evolution & WorkBee!!! Thanks!!!
Fiesta Rally2 R5 MkII
deggster Chefmechaniker
Anmeldungsdatum: 18.11.2013 Beiträge: 131 Bilder im Album: 0 Wohnort: Zwickau  |
Verfasst am: Fr Dez 25, 2020 16:07 Titel: NGP (Next Generation Physics) Plugin |
Cristian Lamas hat folgendes geschrieben: |
What a beauty, Thats what I call a christmas gift!
Just tested it and it feels amazing!
Thank you! _________________ www.mm-rallymedia.com |
pedrodfa Mechaniker
Anmeldungsdatum: 05.03.2019 Beiträge: 60 Bilder im Album: 0
Verfasst am: So Dez 27, 2020 23:49 Titel: NGP (Next Generation Physics) Plugin |
This fiesta rally2 model has the driver built in the model, helmet and everything, which conflicts in VR because it can block the view. Quite unusual, as I think no other model has this. Any solution? |
Fabz Chefmechaniker
Verfasst am: Mo Dez 28, 2020 21:47 Titel: NGP (Next Generation Physics) Plugin |
Yes in the ini you change e_drivers and i drivers from false to true |
smakowy Mechaniker
Anmeldungsdatum: 26.01.2015 Beiträge: 5 Bilder im Album: 0
Verfasst am: So Jan 03, 2021 16:08 Titel: NGP (Next Generation Physics) Plugin |
Did physics regarding driving model change in any way in NGP 6.4? |
Viktor GVRC Veteran
Verfasst am: Mo Jan 04, 2021 00:16 Titel: NGP (Next Generation Physics) Plugin |
There is no indication of that according to the changelog as far as I've read it. Do you sense some particular changes (regarding general drive model or for some specific car physics?) or why do you ask?
The changelog is usually very brief but if important drive model tweaks are made, I would expect those to be announced in some way or another.
German translation / Deutsche Übersetzung:
Laut Changelog gibt es keinen Hinweis darauf, soweit ich es gelesen habe. Spürst du bestimmte Änderungen (bzgl. generellem Antriebsmodell oder für irgendwelche bestimmten Autophysiken) der warum fragst du?
Das Changelog ist in der Regel recht kurz gehalten, aber wenn wichtige Änderungen am Antriebsmodell vorgenommen wurden, würde ich erwarten, daß diese auf die eine oder andere Weise angekündigt werden. _________________ „Lieber glaube ich an Wissenschaftler, die sich mal irren, als Irren, die glauben, sie seien Wissenschaftler.” |
Verfasst am: Mi Jan 06, 2021 13:50 Titel: NGP (Next Generation Physics) Plugin |
thanks DMRally74 & WorkerBee !!!
BUCZEK Lukas Chefmechaniker
Anmeldungsdatum: 10.02.2013 Beiträge: 189 Bilder im Album: 176
Verfasst am: Fr Jan 08, 2021 16:27 Titel: NGP (Next Generation Physics) Plugin |
@WorkerBee and DMRally74 - Lancia Stratos is brilliant! Thank you guys for your excellent Quality!
waldemar Profi - Racer
Anmeldungsdatum: 04.02.2014 Beiträge: 579 Bilder im Album: 66 Wohnort: bad salzungen  |
Verfasst am: Fr Jan 08, 2021 21:42 Titel: NGP (Next Generation Physics) Plugin |
@ Christian & Lukas tolle Fotos ... saubere Arbeit
hat schon jemand erfolgreich die NGP und (oder) die Fixup versionen über den RBR CIT Carinstaller updaten können ? |
Verfasst am: Fr Jan 08, 2021 22:30 Titel: NGP (Next Generation Physics) Plugin |
Hallo Waldemar,
Danke sehr für deine nette Wörter
Zu deiner Frage: ja, sowoh Fixup wie NGP hat bei mir über RBRCIT funktioniert. |
Verfasst am: Fr Jan 08, 2021 22:49 Titel: NGP (Next Generation Physics) Plugin |
Danke Lukas
bei mir funktioniert es nicht ... ist die RBR-CIT version 1.0.6 noch aktuell ?
edit: geht nun doch CIT zeigt zwar beim updaten der NGP fehlermeldung
und die Fixup ist nicht die auf onlineracing.cz angegebene vers 4.xxx sondern 3.0.22.57 aber ich komm damit ins Tournament |
Verfasst am: Sa Jan 09, 2021 01:00 Titel: NGP (Next Generation Physics) Plugin |
Waldi,
die aktuelle Version vom RBRCIT ist die 1.2.0.
Mach zuerst ein Update davon und dann den Rest
Ich drucke dir die Daumen! |
Verfasst am: Sa Jan 09, 2021 14:22 Titel: NGP (Next Generation Physics) Plugin |
Danke Lukas ,
bis dem nächst auf der Strecke , immer gerne wieder auch im
Wartburg ( der ganz in der Nähe von mir gebaut wurde in 'Eisenach'
nahe der Burg ,wo der alte Luther die Bibel ins deutsche übersetzt hat )
PMSRT GVRC Veteran
Anmeldungsdatum: 31.10.2011 Beiträge: 2473 Bilder im Album: 218 Bilder in P. Galerie: 87 PMSRT's P. Galerie Wohnort: Freiburg i. Br.  |
Verfasst am: So Jan 10, 2021 10:15 Titel: NGP (Next Generation Physics) Plugin |
Big thanks "DMRally74" for models & "WorkerBee" for the physics - so great
Bin beide mal in einem kurzen Rollout gefahren machen beide Spaß, jeder auf seine eigene Weise
Die Alpine geht besser als der GT3RS, was wohl dem Mittelmotor geschuldet ist.
Nunja bin ja auch kein Könner is diesen Dingen, leider. _________________ Motorsportliche Grüße : Mike
Fahrerperspektive (korrekter FOV), H-Schaltung mit Kupplung, NGP & Fmod, TrackIR5, sowie alles aus den Workerbee-Labs, etc pp in RBR => Realistischer Fahrspaß & wir sagen "JA zur Gruppe H & A" ! |
A.G. Profi - Racer
Anmeldungsdatum: 11.01.2011 Beiträge: 683 Bilder im Album: 0
Verfasst am: So Jan 24, 2021 20:15 Titel: NGP (Next Generation Physics) Plugin |
Funktioniert der i20 WRC 2020 und der Fiesta Rally 2 bei Euch im Online Plugin? Ich kann mit diesen beiden Autos noch an keinem Tournament teilnehmen. Kann mir jemand sagen, warum dem so ist? Ich habe von diesen Auos die aktuellsten Modelle installiert. _________________ www.gruendauer-racing.com
www.facebook.com/gruendauerracing |
Prill Race Champion
Anmeldungsdatum: 06.01.2013 Beiträge: 931 Bilder im Album: 10 Bilder in P. Galerie: 3 Prill's P. Galerie Wohnort: Tianjin / China  |
Verfasst am: So Jan 24, 2021 20:24 Titel: NGP (Next Generation Physics) Plugin |
Der Fiesta Rally2 funktioniert ohne Probleme. _________________
Verfasst am: So Jan 24, 2021 21:00 Titel: NGP (Next Generation Physics) Plugin |
Das CZ Plugin hat die Modelle vom Hyundai und dem Fiesta noch nicht geupdatet. Das Plugin erwartet derzeit noch die veralteteten Modelle, deswegen werden die Autos da nicht gefunden, wenn man diese schon via RBRCIT aktualisiert hat. Sobald diese auch im CZ Plugin geupdatet werden sind, kann man die Autos da auch wieder fahren. _________________ www.mm-rallymedia.com |
A.G. Profi - Racer
Verfasst am: So Jan 24, 2021 23:06 Titel: NGP (Next Generation Physics) Plugin |
Danke für Eure Antworten. Zumindest den i20 WRC 2020 haben sie als aktualisierten Download verfügbar. Ich dachte auch irgendwie, dass bei Aktualisierung vom Modell, ohne dass sich die Physics ändern, es dem Plugin egal ist.
Wie auch immer, wenn das dort noch nicht aktuell ist, dann erklärt das natürlich den Grund.
Vielen Dank für die Info. _________________ www.gruendauer-racing.com
FIRSSEN Mateusz Mechaniker
Anmeldungsdatum: 18.01.2018 Beiträge: 9 Bilder im Album: 0
Verfasst am: Sa Feb 13, 2021 21:48 Titel: NGP (Next Generation Physics) Plugin |
Any 306 maxi EVO II plans or nope because it's too OP for group A? |
