Fabz Chefmechaniker
Anmeldungsdatum: 24.07.2017 Beiträge: 156 Bilder im Album: 0
Verfasst am: Fr Dez 24, 2021 11:50 Titel: rallysimfans.hu plugin |
2021.12.24
Plugin update:
Plugin version NGP6: 0.53.4987
- RSF and NGPCarMenu plugin updates (Lacka, Mika-n)
- New: Customized "Favorites" selection group in the car and stage menu (press ENTER key on Car and Stage selection menu line). SPACEBAR key press toggles favorite status of a car and stage.
- New: FOV support in freecam (press F9 key in the chaseCam to use freecam. Mouse buttons and a scrollWheel movement moves the camera. Now it supports CTRL key + scrollWheel to adjust FOV. Alternative way to adjust the FOV is to hold down scrollWheel when scrolling it).
- New: TrackIR option in RSF Launcher and trackIR feature in RBR is now enhanced to support full 180° view range.
- New: When camera shaking is disabled via RSF Launcher option, it now disables the shaking effect in the true internalCam view also and not just in bumperCam view.
- New: RSF now supports multiple "broken windshield" textures to simulate randomness of how the windshield is shattered (WS_Broken.dds/WS_Broken1.dds/WS_Broken2.dds/etc).
- New: Support for stages using high resolution textures and LB2 optimized data structures (important for stage authors).
- New: Home/End key support in RSF menus (Home key takes to the first and End key to the last menu line in RSF and car/stage menu lists).
- Improved: The online rally lists at the top those rallies you have already entered ("yellow" colored rallies) to make it easier to find those.
- Improved: Weather setting selections for each stage.
- Improved: TuneCar (setup editor) option increment improvement. Now CTRL+left/right arrow key speeds up the increment more than just holding left/right arrow key down (less aggressive increments when CTRL is not hold down).
- Improved: Original RBR cars disabled in the car selection list (those are not NGP6 physics compatible and caused just confusion among new drivers).
- Fixed: "Missing stage" error message in Online rally didn't always list correct stage names.
- Fixed: The selection of the previous setup in Continue rally was broken. Now it properly selects the previously selected setup.
- Fixed: Car manager fixes.
- Fixed: Audio and custom setup file download fixes.
- Fixed: Pacenote verification fixes.
- Fixed: Grayed out menu lines are now properly skippped.
- Fixed: Sometimes "Call for help" menu was not available.
- New stages:
- Helfstyn (BTB: David Hradil, conversion: J)
- New BTB stages:
- Savo (Mikko Virtanen)
- Korpiaho (Mikko Virtanen)
- Makkola (Mikko Virtanen)
- Kuri Bush 1 (AJNZ)
- Kuri Bush 2 (AJNZ)
- Ubunapa Kabula II ((c) Esko Kytömäki/Tangoteam)
- Kinamba Yala ((c) Esko Kytömäki/Tangoteam)
- Mattila ((c) Justup and BTBfin)
- Hassi ((c) Esko Kytömäki/Tangoteam)
- Cueva Santa II (Zaxxon)
Merry Christmas!
Lacka and Mika-n and the map and beta testing team from RSF |
Matthias Siegl Profi - Racer
Anmeldungsdatum: 12.02.2008 Beiträge: 474 Bilder im Album: 5 Wohnort: Zwickau  |
Verfasst am: So Dez 26, 2021 19:54 Titel: rallysimfans.hu plugin |
Darf man mal fragen ob zur Nutzung des Plugins im nächsten Jahr bereits etwas entschieden wurde?
Bleibt es beim CZ Plugin oder kommt das HU? |
rallyefan238 Race Champion
Anmeldungsdatum: 09.10.2008 Beiträge: 1068 Bilder im Album: 114 Bilder in P. Galerie: 82 rallyefan238's P. Galerie
Verfasst am: So Dez 26, 2021 20:38 Titel: rallysimfans.hu plugin |
Ja eine Entscheidung gibt es.
Was wie genau gemacht wird, wird die Tage bekannt gegeben. _________________ > Nikon D300 + MB10 | Nikkor 18-200mm 1:3.5-5.6 | Nikkor AF-S 70-200mm 1:2.8 G IF-ED | Metzbiltz 58 <
 rally3.de<-- aktuelle Bilder aus der Rallyeszene |
Dika Chefmechaniker
Anmeldungsdatum: 07.05.2008 Beiträge: 148 Bilder im Album: 83 Bilder in P. Galerie: 40 Dika's P. Galerie Wohnort: Leipzig, Germany  |
Verfasst am: So Jan 02, 2022 18:58 Titel: rallysimfans.hu plugin |
Habe mal für alle das alte Rallyeplanungstool von Latex umgebaut und alle Stagenummern des HU Plugins mit eingebaut. Hier kann man jetzt alle CZ-Strecken mit den dazugehörigen HU-Stagenummern sehen.
Es sind jedoch nicht alle HU Nummern drin, da einige Stages ja nicht bei den CZ enthalten sind. z.B. die Tarmac- / Gravel- / Snowmod Versionen der RBR Originalstages.
(p.s. bitte nicht von den VDRM / Nightmod Infos ablenken lassen, diese sind nicht aktuell ! )
Stagetool CZ ->HU
Eignet sich z.B. für die manuelle Umschreibung der persönlichen Pacenotes. (nur händisch, leider)
Euch allen noch ein schönes neues Jahr 2022.
Max |
LaTeX VDRM/GVRC-Moderator
Anmeldungsdatum: 18.11.2007 Beiträge: 10339 Bilder im Album: 144 Bilder in P. Galerie: 21 LaTeX's P. Galerie Wohnort: Vienna / Austria  |
Verfasst am: So Jan 02, 2022 19:36 Titel: rallysimfans.hu plugin |
Danke dir. Super Arbeit. _________________ Noch ein abschließender Verbraucherhinweis: Es bricht uns das Herz, wenn wir uns beim Löschen vorstellen, wie Sie mühsam ein so langes Wort in Ihr Smartphone gefingert haben. (Ihr/e Zensor/in) |
waldemar Profi - Racer
Anmeldungsdatum: 04.02.2014 Beiträge: 565 Bilder im Album: 66 Wohnort: bad salzungen  |
bombus GVRC Veteran
Anmeldungsdatum: 08.11.2009 Beiträge: 2412 Bilder im Album: 372 Bilder in P. Galerie: 129 bombus's P. Galerie Wohnort: Ost-Thüringen  |
Verfasst am: Di Jan 11, 2022 17:38 Titel: rallysimfans.hu plugin |
Wollte eigentlich Danke sagen!
Aber erstens konnte ich nicht mit meinen gewohnten Autos fahren, klar der S130LR und der VFTS ist dann auch okay!! Ich wollte aber mit nem AWD im Schnee fahren, hab dann den Skoda R5 genommen, bin aber nicht weit gekommen, wollte die PN auf Timo umstellen und hab dann was getroffen, aus die Maus!!
Das mit den fehlenden Grp. A8 ist vielleicht eine Änderung im CC, aber einen Test ohne SR ist für solche Sturzpiloten wie mich, nicht wirklich hilfreich!
Der Gute Wille zählt!!
Nimms nicht ganz zu ernst!!  _________________
Verfasst am: Mi Jan 12, 2022 00:43 Titel: rallysimfans.hu plugin |
hallo Stefan , schön das Du es gleich als erster versucht hast ... sollte eigentlich schon 'mit' SR werden ( flieg ja selber ebenfalls oft genug ab ,um das dann dankbar anzunehmen ... muss ich beim nächsten mal besser darauf achten ...
weißt Du ob es bei dem hu ebenfalls (wie bei cz möglich) einen reset zu beantragen (genemigen ) gibt ...
wenn nicht ,wäre das ja eine Option die sich die fleisigen Admins und Entwickler dort unter die Lupe nehmen könnten ... ( da wir es ja nun mal durch einige Meisterschaften gewöhnt waren ... ) |
WAGGES Chefmechaniker
Anmeldungsdatum: 28.01.2019 Beiträge: 129 Bilder im Album: 56 Wohnort: Baden-Württemberg  |
Verfasst am: Do Jan 13, 2022 20:47 Titel: rallysimfans.hu plugin |
Hallo Waldemar,
habe Deine Winterrallye auch ausprobiert. Schöne Pisten.
Bin sogar mal durchgekommen. Bis jetzt als einziger
Sind auch noch nicht viele gefahren.
Roland |
Verfasst am: Do Jan 13, 2022 21:03 Titel: rallysimfans.hu plugin |
Hallo Roland ,
schön das Du bis ins Ziel gekommen bist
ja ,hab schon gesehen das die Teilnemerzahl recht dünn ist .. anders als wenn Frank ( CC ) (eben auch hier bekannt )
was rein zaubert ... da müsste man sich bestimmt erst einen Namen ( der als Anziehunsmangnet fungiert) machen
gruß Waldemar |
Fabz Chefmechaniker
Verfasst am: Fr Jan 28, 2022 14:26 Titel: rallysimfans.hu plugin |
- New: Add Broken Windshield Texture (LEZA) (Choose to install Rallysimfans texture updates)
- New: TrackIR view range extender support in RSFLauncher (makes it possible to use 180 or even more as trackIR range)
- New: FOVCaculator links in RSFLauncher when "Override FOV in cockpit view" is enabled
- New: WrongWay message moved under the timer to make it less distracting. Optional "Hide wrong way" message option.
- New: Default race cam option in RSFLauncher (the default view when a car goes to the starting line)
- New: High process priority during racing and replays. May help to avoid occasional stuttering issues. See ngpcarmenu.ini.sample and ProcessPriority explanation for details.
- New: Custom BTB stages shown in "Test BTB Tracks" stage folder. Non-RSF-online-approved BTB stages are now available in Practice menu to benefit from RSF car selections and setups.
- Improved: Installation and use of custom stages in classic format is now easier (Stage specific subfolder in Maps, TracksXXX.ini, TrackSettingsXXX.ini and TextureFilenameMapXXX.ini file support, xxx=mapID). Shown in "Test Tracks" stage folder in Practice menu.
- Improved: TrackIR with extended view range (user configured)
- Improved: MyPacenote feature automatically merges a custom note file with the latest map data when required (sometimes after a map update custom note may need few updates also. Now this is done automatically under the hood when necessary)
- Improved: RallyRadio delays the pause music until the stage has been fully loaded
- Improved: The red "standard time exceeded" timer background removed as unnecessary feature
- Fix: Stage loading bugfix (surface and in Practice mode "always new / keep previous car state" option)
- Fix: Pacenote verification bugfix.
- Fix: FreezeFrame bugfix in replay mode (RBR was frozen completely if ESC key was pressed during FreeFrame state in replays).
- Fix: Fixed overflow of results list in online rallies causing incorrect row order after service parks.
- Fix: Custom dashboard scaling bugfix in RSFLauncher when resolution was more than 1920x1080
- Use default RichardBurnsRally_SSE 4Gb patch (Allows 4GB of virtual memory for RBR on the x64 platform)
- Other bug fixes
-New Stages:
- Zaton (Mato22)
- Zaton II (Mato22)
-Update Stages:
- Rallysprint Hondarribia 2011 (Eneko Celayeta)
- Vargassence (Martinez) (Installer fix) |
Penny_Menny GVRC Veteran
Anmeldungsdatum: 28.03.2010 Beiträge: 1770 Bilder im Album: 120 Bilder in P. Galerie: 84 Penny_Menny's P. Galerie Wohnort: Nordhessen  |
Verfasst am: Sa Apr 23, 2022 00:10 Titel: rallysimfans.hu plugin |
Ich hab mir letztens mal wieder das RSF Plugin gezogen und vertreibe mir hin und wieder dort die Zeit aber leider hab ich ein kleines Problem, ich bekomme einfach kein Dash angezeigt. Mit viel probieren hab ich die Ganganzeige hinbekommen aber das wars.. jemand eine Idee? Liegts vielleicht an der Auflösung? Fahre 1600x1200.. _________________ ~ Opel Astra F 16v ~ |
Caterham GVRC Veteran
Anmeldungsdatum: 08.03.2005 Beiträge: 1692 Bilder im Album: 299 Wohnort: 40882 Ratingen  |
Verfasst am: So Apr 24, 2022 10:34 Titel: rallysimfans.hu plugin |
Das kann man im "RSF Launcher" einstellen,
unter Cockpit & Dashboard. _________________
https://discord.gg/KVS2GWGUHP |
Verfasst am: Mo Apr 25, 2022 21:34 Titel: rallysimfans.hu plugin |
Dort hab ich schon sämtliche Dash's ausgewählt aber ohne Erfolg. Ganz am Anfang hatte ich den normalen, wollte etwas rumprobieren aber seitdem geht keiner mehr.  _________________ ~ Opel Astra F 16v ~ |
Du kannst keine Beiträge in dieses Forum schreiben. Du kannst auf Beiträge in diesem Forum nicht antworten. Du kannst deine Beiträge in diesem Forum nicht bearbeiten. Du kannst deine Beiträge in diesem Forum nicht löschen. Du kannst an Umfragen in diesem Forum nicht mitmachen. Du kannst Dateien in diesem Forum nicht posten Du kannst Dateien in diesem Forum nicht herunterladen
 Vereitelte Spamregistrierungen: 186627
