Popping and cracking sound
Hellracer
Anmeldungsdatum: 29.01.2015
 BeitragVerfasst am: So Apr 12, 2015 19:52    Titel: Popping and cracking sound Antworten mit Zitat Back to top
Workerbee i know this is not the right place to post this but i dident find any whare ells.
I have a little bit of a crackeling popping csr sound when i wath repleys, some cars are worse then others, for exampel DS3.
Du you Workerbee or somone ells have any ide of what causing this.
I appriciate any help i can get with this problem.
 BeitragVerfasst am: Mo Apr 13, 2015 06:19    Titel: Popping and cracking sound Antworten mit Zitat Back to top
Well, we have 4 DS3 vehicles. wink
Anyway, this behaviour is by design.
But you can play with the values
Squeeks=1.0 ; effects
Suspension=1.0 ; effects
in the "audio.ini" file located in RBR's root directory.
Set these values so some lower value and you will be fine.
Hellracer
 BeitragVerfasst am: Mo Apr 13, 2015 10:04    Titel: Popping and cracking sound Antworten mit Zitat Back to top
Ok i will try that thanks smile
Modifieds: 2004-2006 by Adi   •   Impressum   •   Datenschutzerklärung
Vereitelte Spamregistrierungen: 200255
